May 12, 2026
Spring Car Maintenance Checklist: How To Prepare Your Vehicle for Road Trips
Hero Placeholder
GS
Good Sam
Imagine planning your first spring getaway. The family is packed, the route is mapped, and excitement is building. Then, just miles from home, an odd noise or warning light appears. A minor issue that could have been caught early suddenly turns your adventure into a stressful delay.
After months of cold weather, road salt, and fluctuating temperatures, spring car maintenance becomes essential. A thoughtful spring car maintenance checklist helps you identify small problems early, improve safety, and prepare your car for longer drives ahead as warmer weather arrives.
Many of these checks are simple enough to handle at home as a part of routine spring vehicle maintenance. For everything else, or when the unexpected happens, roadside assistance provides dependable support when you need it most.
Quick Spring Car Maintenance Checklist
  • Check tire pressure and inspect tread depth for uneven wear
  • Inspect brake pads, rotors, and check brake fluid condition
  • Test battery charge and clean corrosion from terminals
  • Check and top off engine oil, coolant, brake fluid, and washer fluid
  • Inspect and replace engine and cabin air filters if clogged
  • Inspect belts and hoses for cracks, fraying, leaks, or soft spots
  • Test headlights, brake lights, turn signals, and hazard lights
  • Replace worn windshield wiper blades and test washer spray
  • Check suspension and alignment
  • Wash undercarriage
Spring Car Maintenance Checklist for Road Trips
